My code is e74 and 1022 for my 360 and i'v done alot of research and all say the exact same thing. (problem with the av cord or encoder chip) but is there a way to check which one of those 2 problems it is without buying a new av cord for 20$ or sending it in to microsoft.
Most likely it is the cord because the cable on the one you have may not be the right strength,same as coaxial cable for regular cable will not work on a satalite box,so it will probably be worth the 20 to find out.just keep packaging neat and try it and if it does not work ,return it.hope this helps you
