Whirlpool DP940PWKQ Free-standing Dishwasher Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convert a whirlpool portable dishwasher to undercounter
How do I convert a whirlpool DP940 portable dishwasher to undercounter?
Garth Jackson
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Dec 30, 2009
Garth Jackson
Expert
Level 2:
Scholar:
Answers
93
Questions
Helped
33362
Points
232
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Dimensions for whirlpool dishwasher du910pfgg1
The vast majority of undercounter dishwashers measure approximately 24 inches in width, 24 inches in depth and 35 inches in height with adjustable feet. This means that the rough opening in your cabinets must be 24- by 24- by 35-inch. The dishwasher itself may be somewhere around 23 5/8 by 23 5/8 by 34 inches
Whirlpool undercounter dishwasher: ..will wash and dry satisfactorily. Will not drain water from the base of the machine at completion. Thanks
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 09, 2011 • Dishwashers
2answers
An internal 'hose' blows when dishwasher is used.
Hello. go to the site called sears parts direct. put in your model number and u will get an excellent schematic showing you exactly how it goes together. j.
2helpful
2answers
I want to install my portable ge nautilus dishwasher in my cabniets
GE has a kit available for the undercounter installation of this dishwasher, I recommend the purchase of this kit to simplify your install.
GE kit # WD35M34
Good Luck !
I own a whirlpool undercounter dishwasher model number DU925 scgq3, and it will not totally drain. We have taken the drain hose off and no blockage? Please HELP!
hi did you take the drain hose off at the sink or off at the motor if not at the motor then check the motor drain hose thanks the appliance doc
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
