The most common thing here is the presure switch ,either not reading correctly or blocked,you would need to pull the unit out and lay on its back.Then remove the bottom cover plate,you need to look for a round plastic unit it will have two or three wires coming from it and a thinnish plastic tube fitted to the front,the unit is flat on bottom,the wires connected to the top and tube comes from the rounded edge.
Pull the tube off and blow into it untill you hear the airflow inside the machine,next blow into the switch where the tube is connected and make sure you hear a click and click again when you stop blowing,put the unit and machine back together and test.If this does not solve the problem then we need to look at the timer or controller board the timer and board usually need to be replaced if they have gone fualty.(not sure wich your machine has you do not mention a model number)if you need further assistance then let me know and we can see what we can do.
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
