Question about Xerox WorkCentre 214 Laser Printer
Xerox Copier 214
The prompt is flashing U4 on the Xerox 214 copier.
  • Mollettapnc7 Feb 01, 2008
    YOU GUYS ARE THE BOMB! THANKS SO MUCH! I WILL TELL EVERYONE I KNOW ABOUT YOUR SITE!
    THANKS A BUNCH!
    MY RATE ISN'T RIGHT! I GIVE YOUR ADVICE AND SOLUTIONS TO MY PROBLEM 4 STARS!
    President:
  • 2,072 Answers
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fiser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Posted on Jan 29, 2008
  • Rick Kasper Feb 01, 2008
    Glad to help.
    LOL. thats fine. No big deal as long as you got it resolved.
    Thanks.
SOURCE:
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Copier is a 214 and shows U4 code
turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
Sep 06, 2009 | Xerox 212 Laser Printer
Copier is a 214 and shows U6 code
A U-6 means the memory on the main board failed.
If the machine is old, the battery on the board is old and not holding the values in the machine.
Replace the main board will correct the problem.
Since it is in the middle deep in the machine you might need to have Xerox repair it for you if they still provide service to this model.
Good luck.
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
My xeros 214 copier has gone wrong and the no U4 is coming up, i do not have a manuel thanks terry
If it does. Remove the fuser and clean the buildup off the thermistor.
May 15, 2008 | Xerox Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Open Questions:
See all Xerox WorkCentre 214 Laser Printer Questions
Xerox WorkCentre 214 Laser Printer Logo
319 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
