I'm looking for a manual that explains how to take it apart so I can fix the leak. Seveal screws but there are some strange fastener not sure how they are ment to come off.
Here is how I solved this problem. I had a small needle nose vice grip, the 'nose' is about 1 1/2 inches long. I tried to clamp the oval shaped screw heads in the vice grip in a perpendicular manner, ie the vice grip was extending away from the side of the coffee maker. There is a recess in the plastic where the screw heads are seated so they are flush when tightened. The ends of the vice grip were slightly too large to fit in this recess. So I ground down the ends of the vice grip so it could fit in the recess and grip the oval end of the screw. After clamping it tightly, I used an adjustable wrench to turn the vice grip and the screw to successfully remove them. I replaced them with normal Phillips screws during the reassembly.
