Usually, when your battery has been in the charger long enough for it to be fully charged, the indicator light either changes color, or turns off. This indicates that the charge is complete.
Does your light do either, change color or turn off?
If neither of these works right, check your user manual, usually in the back, which will tell you what the indicator lights mean.
If your camera and battery are doing what they are supposed to be doing, then you may have bought a faulty camera, or the battery which came with it was faulty.
Be certain to read the manual very carefully, to be certain that you are following the instructions properly. If you have done everything right, then return the camera and or battery to the place from which you purchased the camera, and have them check it out to ensure that all is proper.
Have you tried another battery? Have you tried recharging the battery you have again?
