I have a Kozy World propane wall heater. There are 5 bricks in the heater. When I light it only 3 glow bright orange. The others have the blue flame flowing over the surface of them. I tried blowing the bricks out with an air compressor. It looks like it helped one of them slightly.
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Testimonial: "Thank you very much for the info. There was some trash around the opening of the 2 jets. I cleaned them out with a tip cleaner and now it works fine."
