Radio Shack Accurian APD-3955 Logo
Anonymous Posted on Dec 30, 2009
I have a accurian portable dvd player APD-3955 and it works but the charger doesnt charge it anymore. Now the battery died and I was wondering if it just needs a new charger. I got it June 2008.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Jun 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
4436
Points
16
I had the same problem and I found out that is definitely the battery. I had used mine only a few counted times and after 1 year the battery would not charge. I would plug it and the charge light would turn on and stayed for about 4 minutes and then turned off. I called axion and talk to customer support. The tech said that the internal batteries only last for a year whether you use the DVD or not. They would replace the battery for $60 + shipping costs. As you can see... it is not worth it....sometimes you are lucky and get good stuff for cheap but sometimes... you just get what you pay for.... and this is one of the cases. Yes, I am also very disapponted. What a piece of junk!!!! I can still watch DVD with either the charger plugged in or with the car charger. But it lost its Portable side.....
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
3873
Points
29
You need to buy a new charger; however' it might be the battery, double check that your battery works fine and then get the charger, or what you can do is the following:
buy a new charger, plugg it into your dvd, if everything goes back to normal then it was your charger, but if the problem continue return your charger and get a new battery
Testimonial: "Thanks"
1helpful
I need to purchase a charging plug. A DC-9V 1.5A plug for a Accurian 7" LCD monitor portable DVD player. Model # APD-3955. Can you please help?
look on amazon web site under electronics & photo and type model number in that is on mains adaptor
hope this helped
My acurrian apd-3955 doesn't charge and play dvds
after 2 or 3 years of service the battery needs to be replaced.
Batteries have a finite charging "cycles". These cycles runs out every time you charge the battery.
Do i need to charge it with the power on or the
keep the power off or the battery will not charge properly
2answers
Accurian Model APD-3955 Portable DVD player
I had the same problem. It turns out that my adapter for my Dell Digital Jukebox mp3 player works great. You might be able to order one from Dell. I hope this helps.
Accurian portable dvd won't read disk
if you here a clicking sound then you need to replace you ribbon wire. it is attached from a circuit board to its lens.
Battery Drain
cheap battery when not using it take them out
2answers
Accurian Portable DVD player
Dirty DVD or bootleg format on the content?
3answers
I lost the remote to my APD-3955 portable DVD player
APD-3955 portable DVD vemote, dvd show room is avlible pleaase go to dvd show room.you will get soon. if internet you ask remote will come by post so many days after will came my suggens is your nerest shop only best.
thanks
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
