Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the Craftsman 139.53681B remote compatible w/ 139.53753 remote
Is the Craftsman model 139.53681B remote (blue buttons) compatible with the model 139.53753 remote (black buttons)? I just got a new Garage Door Opener [Model 139.53985DM] and cannot get the older 139.53681B remote to program with the new opener.
Thanks,
Andy
  • deadcandance Jul 16, 2019
    Ok so I am in Canada and I bought this used Craftsman remote keypad that you install on the side of your garage door on the outside of your house. I assumed that as long as the keypad brand was Craftsman, Liftmaster, Chamberlain or Wayne dalton, that any keypad of these brands would work with any of these brands of garage door openers. WRONG!! I spent $40.00 for a used keypad only to find out that it is not compatible. So to avoid you all from making the same mistake...here is what I learned or know now. First off it is very important to try to find out what colour the square plastic learn button on the actual garage door motor was that the remote keypad you are looking to buy , was used with. It is also a good idea to find out what the FCC ID # is on the back of the remote keypad you are looking to buy.Once you have the FCC ID# for example mine was FCC ID# HBW1631. You can type into Google searchbox "FCC ID# Lookup" and that will take you to the FCC's website. If a search box does not automatically pop up, you scroll on the left side of the page and look for "FCC ID Search". A box pops up. The first box is called "Grantee Code (first 3 to 5 characters)...mine was HBW. The second box underneath is called "Product Code (remaining characters of the FCC ID#).......mine was 1631. Hit search and a result should pop up, In that result you see a lot of info but at the far right you will see the lower and upper frequency range of your remote keypad you are either selling or planning to buy. Mine was 315MHz upper and lower range. So that means that my remote keypad will only work with garage door motors that operate on or between a lower and upper range of frequencies that include 315MHz. Now we have to find out what frequency the garage door motor is. If you are buying the remote keypad....as the seller what colour the Learn Button is on the garage door motor. For my remote keypad I bought, it worked with a Green or Purple Learn Button on the motor. So the keypad I bought would not work with my motor with a red learn button. To find out what frequency your garage door motor operates at, you can either call customer service for the brand you own and give them the model number.Or Google the model number to search what frequency the motor operates at. I had a hard time googling it so I just called Chamberlain customer service and they told me my motor is 390MHz. So now I know the frequency range my garage door motor operates within, I can look for used remote keypads, ask the seller what the FCC ID# is, then type it into the FCC ID Search Lookup website to see if the remote keypad frequency falls within the operating frequency range of the garage Door Motor. Hope that helps a bit guys and gals. Kev
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458661
Points
8183
They have changed the radio frequency and the two will not work with each other.
I need the manufacturing year/date of the 139.53977SRT garage door opener. I want to install a wireless keypad and I need to know this to program correctly.
If you mean the Craftsman 139.53977SRT, the manual has a copyright date of 2001. Thus the garage door opener was probably built in 2001 or later; however, I don't know how long they made the model. Manuals Lib has the manual here: https://www.manualslib.com/products/Craftsman-139-53977srt-2890746.html . The directions for adding a compatible wireless keypad are on page 36, https://www.manualslib.com/manual/497186/Craftsman-139-53977srt.html?page=36#manual . The appropriate keypad is 139.53684; I found an equivalent here: https://dooropenersandmore.com/sears-craftsman-139.53684-compatible-wireless-keypad . Note: this keypad isn't guaranteed to work with all units; check the color of the Learn button or the original remote button colors.
I hope this helps.
How to change code on model 139-53753
What is it you want to do? You cannot just change the code without purchasing new remotes and not using your old remotes.
I have a Model 2000 Chamberlain 1/3HP garage door opener manufactured 02/91 with a round yellow "learn" button, lost remote. Bought a replacement chamberlain remote, Model 956 which is supposed...
If the learn button is 'amber' the model 956 remote should work with it. Try this method for programming just in case your aren't.
Hold the button down on the remote while your press and immediately release the learn button. Main light should flash.
There is always the possibility that the receiver has quit working.
How do you program a craftsman keypad remote model no. 139.53776 for a chamberlain garage door opener?
Press and immediately release the smart/learn button on the back of the opener and then walk over and key in your 4 digit PIN and press enter.
If this doesn't work the 2 units are not compatible.
1helpful
Older model keyless will not open new craftsman garage opener.
inside or on the back of the opener motor housing or sometimes on a remote receiver (an external box connected to the motor unit and a push button) is a set of switches ... if you take your opener apart you should also see a set of switches ... those have to be set the same way as the opener ... thats the code select ... make sure the battery is ok .. you can check with sears to see if your older remote is compatable ..
1helpful
13953992D need a replacement manual for that model #. craftsman garage door opener. moved in to house, former tenant took remote, do not want to buy a new one. do i have to just buy the remote? or can I...
A replacement remote for your unit runs around $40.00 and the manual is $5.00. The remote is part number 53753 and the manual is 114A3129. FYI the manual will not have instructions for programming your car. The cars owners manual should have those instructions. The frequency of your opener is 315mhz and if your car is older than 2005 it most likely will not work at all.
4helpful
2answers
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
