Cyberhome CH-DVD 300 DVD Player Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect to tv using converter boxs
How to connect dvd to tv that uses a converter box can't find manual for dvd my father had it connected to tv before he got the converter box and there was no problem
Anonymous
Level 3:
  • Master 603 Answers
  • Posted on Dec 29, 2009
Anonymous
Master
Level 3:
Answers
603
Questions
0
Helped
234483
Points
1582
DVD does not need to go through converter box.
The converter is only to receive the digital TV through the antenna. DVD might have to switch to another connection on the TV, and if it doesn't have enough connections, you have a problem.
2answers
While watching tv, we lost sound. We thought it was the tv but when we use the wii or netflix through the wii, we have sound. We are using a Zenith tv digital converter as well as have things routed...
Reboot the digital converter box by unplug,replug it back like 10-20 mins later.If u still getting the same problems no sound,tries by checking out the RCA cable connections,tries take out the red wire and check for damages and plug it back in or tries changes another RCA cable set all to gether.After new set of RCA cable should be working 100,if not the digital converter box is the problems,than now must change the digital converter box,this box no longer on sale by those big box stores.If u require to change the digital converter box tries websites like Amazon.com,Ebay.com to buy those converter boxes.
1helpful
2answers
1helpful
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
How do I hook up the dvd/vcr to the tv and the converter box
The antenna is connected to the converter box then connect the box to the vcr on channel 03 throw the rf connector now connec the vcr to the tv set and use the converter box to move the channels you want to see good luck
Connecting tv, converter box, vcr, dvd player
You will need a splitter,
pixel.gif --> #bubwrapper { position:relative; width:98px; height:113px; } #bubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } #bubLyr2{ position:absolute; visibility:visible; width:120px; height:0px; left:35; top:-20; padding:0px; } #bubLyr3{ position:absolute; visibility:visible; width:120px; height:0px; left:-61; top:-32; padding:0px; } #bubLyr4{ position:absolute; visibility:visible; width:120px; height:0px; left:200; top:-20; padding:0px; } #bubLyr5{ position:absolute; visibility:visible; width:120px; height:0px; left:-30; top:-32; padding:0px; } function showCustomPopUp(thisUrl,thisName,theseParams) { remote = open(thisUrl, thisName, theseParams); } function showEnhanced() { remote = open("/largeImage/index.jsp?LargeImageURL=" + escape(document.path.enh.value), "largeImage", "width=505,height=525,left=0,top=0"); } function verifyFields(submitProcess,formObject) { if (submitProcess == "wishlist") { formObject.wlName.value = "wlName"; formObject.submit(); } else { formObject.wlName.value = ""; ajaxAddToCart(formObject); } } function popUp(URL) { day = new Date(); id = day.getTime(); eval("page" + id + " = window.open(URL, '" + id + "', 'toolbar=0,scrollbars=0,location=0,statusbar=0,menubar=0,resizable=0,width=300,height=50,left = 337,top = 284');"); } function submitCompare(thisForm, thisFormField, prodLength) { var prodsToCompArr = thisForm.gridProductIdsToCompare.value.split("_"); var prodList=""; for(var i = 0; i #stsbubwrapper { position:relative; width:98px; height:113px; } #stsbubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } function showMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'visible' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'block' + "\""); } function hideMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'hidden' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'none' + "\""); } pixel.gif $10.99
prs1c-2159957t98.jpg rsk_ourexclusive_icon.gif 2-Way Hybrid Splitter pixel.gif Model: 15-1234 | Catalog #: 15-1234 pixel.gif
Use to divide a signal to feed two TVs or VCRs, or to combine signals for transmission on a single c...
Connect conv box and vcr on the two terminals and the single one to the tv.
Hope this is a Fix Ya!
Connecting my DVD Player to my Digital Converter Box
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
JUST MATCH UP THE COLORS.
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
5answers
Tv/digital converter box & vcr-dvd hook-up
Hi Karen, I think you are having connection issues. Can you provide specific details of the connections? Thanks, Mike
14helpful
3answers
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
