Try unplug the battery and direct plug the AC power adapter, see what happen..........
and everything ok, that means your battery has problem.
if the laptop don't even turn on, that means the connector of your laptop (the power connect may have problem, THE IS THE WROSE CASE, YOU NEEED TO REPAIR YOUR LAPTOP)
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If
everything is plugged in correctly and it still will not power on,
follow these steps to complete a 'power reset' of the notebook.
