What is your Model Number it will be on back of TV?
If your TV is A DLP problem will be the Color Wheel Part# should be BP96-00674A Encompass Parts Distrubtion has them for $129.69 you can also go to there Website and Look up Parts for your TV just type in your Model# their Ph# 1-800-638-3328
Yes ,Color Wheel turns at 9,000rpms per second so what is happening is it is locking up bearings are bad they have a very tiny motor to them!
Go to Encompass Parts Distrubtion onlline Look up this Model # HLP5063W look for part number BP96-00674A they will show you a picture of it , It is Located behind your Lamp when you Pull Lamp out ,use a Flash Light you will see it Watch how it turns when you turn TV on.I will be online all day and most of the Night so if you need to know anything else I always Keep a CK on my Email.
It will be on right side where Lamp is Pull Lamp Out.Located right behind where Lamp plugs into.
I would just let it Play for now and see what it does,but if it does the same thing again you know what to do now, I have heard of where the Color Wheel has just broke and flew into tiny pieces, but most of the time they either freeze up or begin to make a loud squealing noise. I would just keep a watch on it for now! Anothr clue to is it does take its time shuting down to turn off. Good Luck with your TV.
PS. If you happen to need anymore help just let me Know! Thank You for Trying FixYA!
Awwe I knew you were going to ask me that. I am at work right now, so I am not in front of the TV.
So the color wheel would affect the TV Picture Freezing? The colors are fine. The picture freezes then the audio goes out, and screen goes blank. When turning off TV it takes it awhile to shutdown.
Ok I will email you back after Iook at this. Which side of the TV back Paneling should I open to see this color wheel?
Ok my Model is HLR5667WAX. I have placed my TV on the floor, unplug the power and the HDMI cable, then I reconnected everything and it has been working for 20 minutes thus far. It would have usaully started having the issue. Should I still look into the color wheel? I listened to the wheel spinning it seems to be fine.
