I have a Battery Tender 12v 1.25a battery charger I have been using for 6-7 years. I plugged it in for use on motorcycle and I get nothing. I checked battery on bike with a volt meter and still get good voltage, so not bike battery. Checked leads from Battery Tender a get no voltage. Opened up battery tender and get voltage on secondary of transformer. Looked for fried parts and looks good. Without going and further, I am looking for suggestions? Also no lights on front panel light up when plugged in.
Thanks
Bob from Idaho
Remember secondary voltage is AC like the primary voltage, only its reduced typically 120vac primary and 12 or 18vac secondary then the ac secondary is rectified using a bridge rectifier to get the 12vdc then a filter circuit is applied to remove any electrical noise.. any way the problem is with the dc voltage side of the circuit and unless you know how to troubleshoot the circuit you will not be able to repair it. my experience says it might be a bad bridge rectifier.
Testimonial: "Thanks for your help as I am not trained to troubleshoot ic's and such I will go ahead and replace the charger with a new one. "
