The bowl screws into the base and can get quite tight if the mixer has been turning thick dough or other mixes. We usually tap the handle on the bowl with the palm of our hand a few times and that generally frees it. The other posibility is that the bowl was put into the base slightly askew. This could be more of a problem as this can cause the base plate to get damaged. Usually though if this happens you would have noticed some bad noises almost instantly you turned the mixer on.
Testimonial: "Thank you for your feedback"
