Apple iPod nano Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipod woulnt connect to itunes
I plug my new 5th gen ipod nano into my computer with my usb cable and its starts connecting and then i starts ejecting right away.on itunes screen it says..An Ipod Has Been Detected, But It Could Not Be Idnetified Properly.Please Disconnect And Reconnect The pod And Try Again. and i disconnect my ipod and the usb cable many times and the same thing happens
Anonymous
Level 2:
  • Expert 201 Answers
  • Posted on Jan 29, 2010
Anonymous
Expert
Level 2:
Answers
201
Questions
0
Helped
51235
Points
446
Reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Then connect it to your computer and see if it is recognized by iTunes.
If not, try other USB ports on your computer, especially any on the back panel.
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Unlock
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
A1199 unlock code
1helpful
It is modle a1320 and i fogot the skrean lock pass
  • Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    I hope this will help you...
  • 0helpful
    When I try to download music from pc to my ipod, pc says connect
    Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
    - if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
    -Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
    1>www.apple.com
    2>Click on the tab SUPPORT
    3>Select iPod+iTunes
    4>Select iPod nano 4 r 5th gen
    5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
    -if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
    Try wit al dese steps.. hope sumthin works out 4 u..
    If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
    IPOD NANO 8 G is locked. How do I unlock?
    Plug the iPod USB cable into the bottom of the iPod Nano.
  • Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
  • Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
  • Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
  • Click on the "Sync" button to establish a connection between your iPod and the computer.
  • Click on the eject symbol next to your iPod's name after the syncing process has finished.
  • Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
    WARNING
    To unlock your iPod Nano, you must connect the device to the computer it has been previously synced with.
    2helpful
    2answers
    My ipod ask for a sercurity code whats that i dnt know wat it is its a nano how can i get code
    1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
    2. Step 2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
    3. Step 3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
    4. Step 4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    this should help
    Hi I've bought the new 5th gen ipod nano and
    its impossile. you can only upload songs and games onto the ipod. sorry.
    Top Apple Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    ZJ Limited
    ZJ Limited
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
