Microwave Ovens Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
  • ostrolga Dec 29, 2009
    Thanks, all the same....
Garth Jackson
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Dec 29, 2009
Garth Jackson
Expert
Level 2:
Scholar:
Answers
93
Questions
Helped
33362
Points
232
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
During cooking,microwave stopped,no power.
Not good news; Panasonic uses a technologically superior power supply with higher efficiency but an overall worse record than those using a 'linear' supply with far fewer parts and a good track record of reliability.
The modern (switched mode) power supply places a lot more stress on components and requires more and higher quality parts than the old-style circuit.
1helpful
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
1helpful
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
8helpful
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Our Panasonic "the Genius" Model No. NN-S562WF 1200W Microwave has the following problem: We set it for the required minutes, it goes for about 40 seconds then stops - there is no heat happening at all.
hi that is one of 2 possible faults it is either the magnetron or the invertor board (panasonics "great idea" of replacing 3 simple more reliable components (transformer capacitor
9helpful
2answers
Panasonic Sensor 1250W Microwave cycles off after only 5 seconds.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector.
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Microwave not heating and countdown lasts 20 seconds before stopping. put food in and start as normally do then it stops. Microwave is the genius 1200w.
It sounds like it is the "magnetron" has given up. In any Microwave there is a device called magnetron. This is the device which radiates microwave to heat up anything inside for set time.
Before the device gives up most of the time usually the microwave makes little bit of loud noise. Usually it happens when there is abnormal power.
Remedy: Any qualified technician should be able to replace it. The spare is available from the service centre of the manufacturer. In most cases spare is expensive and it is better off to buy another one.
1200w Genius microwave, about 4 years old. Has been working no problem until today. When I press start, its starts ok but cuts out after 23 seconds. It does this on every setting.
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
