How do you download from built in memory to memory card fs10. i can't find it in the manual on how to transfer from built in memory to the memory card.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Do you really want to connect your camera to your computer?
Do you really want the Panasonic software when there are so many better alternatives available, such as Picasa ( http://picasa.google.com )?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
You can download the manual and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/flash_memory_camcorders/fs10#BrochuresAndManuals
User guide for Panasonic FS10 is available for download here:- http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=188593&fmt=PDF&lang=en&src=3&uilang=en-GB&model=DMCFS10
You need to format your camcorder's memory card using the camcorder itself. Navigate through your camcorder's menus and format it from there.
If you can't really do the format in the camcorder since it is no longer detected, try to reformat that memory in your PC using FAT (not FAT32) if there is a format option. If it is only FAT32, then format it anyway unchecking the "Quick Format" option.
Make sure that your computer is clean and no malware or viruses present since they will write a hidden files and folders in your memory card making it unrecognizable by your camcorder.
pg 16 of your owners manual:
• Picture data recorded on the built-in
memory or a card can be copied from
the built-in memory to the card or vice
versa. (P90)
See page 90
heres a link to your om if you dont have it
