Televison & Video Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The model number is no longer visible on our tv
The model number is no longer visible on our 52'' rear projection (BBE D-ILA?), and we punctured the screen while moving into our new home. I would really like to replace the screen instead of buying a new tv, and would like to know how to go about doing this without having the model number.
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Dec 29, 2009
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302436
Points
1655
Howdy,
Most TV shops have old setting around the shop that they could cut and fit your TV.
Or, some TVs have the model inforation on the inside of TV, just remove back (bottom- NOT top).
Good Luck, big IRISH.
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
7answers
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
My 52 inch rca tv is chirping
The model indicated is a older set but chirping usually means a short in the deflection circuit. Is model number correct?
If the model number is correct (chassis number on back should be something like PTK195) it has a "Light Box" which is entire guts of the set---it can be removed and operated with the remote for troubleshooting.
If model number is correct the set may be too old for any extensive repair as some parts are no longer available for it.
Let me know if you have questions.
Volume out on a jvc bbe d-ila tv, what can i do to fix it?
Cannot get sound on JVC BBE D-ILA, what do I do to fix it?
I am trying to change out a bulb in a HD-ILA
I have a tip which explains the procedure at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv Let me know if you need any more help.
hardrocko
Thanks for using FixYa
52" Hitachi tv isn't as bright as it's supposed to be. What could be the problem?
What kind of tv is it. If it's a rear projection crt type then have it cleaned. If it's a DLP or ILA using a lamp . Replaced the lamp. If i's an LCD or Plasm have it serviced. If it's acrt direct view replace it. The crt is going out and cheaper to replace than repair. Hope this helps.
1helpful
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
7helpful
2answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
