Hi I Have sony ericson 250i Cell phone with standard headset . I listen to Radio on it For a month then one day I plugged in the headset and it did not recognise the headset so the radio would not work. It is no good for hands free either as the phone does not recognise that the Headset is plugged in.
Paul
SOURCE: Bluetooth headset Nokia BH-600
I too have the same problem. My phone is a Nokia E61i and I upgraded the software a few weeks ago and since then the headset does not work. I can get the phone pair and recognise the headset, but I hear no sound through the headset. I have tried pair the phone and earpiece a number of times, but no luck.
SOURCE: I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
SOURCE: I have purchased a BW900
in windows xp!!!
click start
all programs
accessories
entertainment
volume control
click devices
recording devices
check the box for your default device..
Vista / Windows 7
right click the speaker icon to the bottom right of your screen (tl bar)
click recording devices.
click set as default,, you may also adjust and set up the device..
SOURCE: Is Blue tooth headset Plantronics Explorer 210
Your headset must be in paring mode, in order to be paired with your phone. If, after turning it on, the indicator light doesn't alternately flash in red and blue (thus indicating it is in pairing mode), it has, most probably, been paired to another phone before. In this case, turn it off, wait for the indicator light to turn red, and, then, off. Then, turn your headset on again, and hold the call button until the indicator light is flashing alternately in red and blue. Either way, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process has been successful, your headset will enter the stand-by mode.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards,
Carlos
