CHECK BREAKER POINTS
burned, dress smooth with file or fine stone. Do not
use emery paper or emery cloth. Measure gap with
thickness gauge; gap points at .020-inch (0.51 mm).
Ignition breaker points, Figure 16, must be correctly
gapped. Crank engine to fully open breaker points
(1/4 turn after top center). Loosen locking screws (A)
and turn cam (B) tQ adjust. Tighten breaker points
and recheck gap.
Ignition points should break contact just as the 20-
degree timing mark aligns with the flywheel timing
mark. Final timing is corrected by properly shifting
the breaker point box on its mounting and using a
timing light. If specified timing cannot be obtained by
positioning the breaker box, make sure timing marks
on gears are aligned.
www.partsfortechs.com > Home > Generator Part Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t... Jun 8, 2013 - 3 posts - 3 authors
Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Depending on what Onan 30KW you have it maybe possible. If it was intended for residential use than no, it does not have the right alternator insulation class, or PMG style alternator. Also what size welder amps? Is it 1 phase or 3 phase. Let me know Onan model and I can advise better
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
