THE ELECTRICAL CORD DOES NOT REWIND COMPLETELY ... WHEN REWINDING IT LEAVES ~ 3FT OUT OF THE CANISTER ... I have cleaned the cord & made certain that the cord is not kinked or twistedc
I took off the dust canister and then the 2 Phillips screws on top of the rewinder. I was searching how to get at the rewinder so I took out the HEPA filter and holder. I then pressed down on the rewind leaver and it rewound. I am not sure why but maybe what I removed was putting some pressure on the rewind mechanism or I just had good luck.
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
This is a common on some of the reviews I have read. The wires tend to break and sometimes wires get pulled from the motor itself. Problem - Vacuum doesn't go on at all. Solution - You have some sort of electrical problem. Proceed to the section on 'Finding Electrical Problems in Canisters' if you have a canister, or 'Finding Electrical Problems in Uprights' if you have an upright...
Hi
It could be two things = one problem is that the cord in Sebo's K model has a bad habit of shearing thanks to its auto pull rewind mechanism. This would have to be replaced by a Sebo repairer.
Or it could be the actual electric socket if the bonded plug is loose - if there are wires visible at the end of the plug then the plug would have to be replaced. Its a common fault on Sebo's K models when the power stops thanks to shearing cords.
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
