Your pipe could be clogged or you may have a clog in the impeller. Check the pump basket and if it is cracked then it is probally in the impeller and you may be able to reach it with a screwdriver and needlenose. If you have a crack in the skimmer basket it could be in the line and you can check this by putting a kitchen sponge in the skimmer and if it comes out in the pump the line is clear. If it is clogged you may be able to clear it with a flush bag you can get at any hardware store. If that dosn't do it you will need to get a pro. Good luck.
