Question about Panasonic SDR-H80 Hard Drive Camcorder
Software incompatible window 7
I used the software for my cam recorder and it says it is not compatible with windows 7 . I have a Panasonic SDR-H80 \HDD Video camera
  • 3 Answers
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Posted on Jan 03, 2010
  • thesupreme Aug 30, 2010
    thanx for that. but now it says "the Device in not compatible for importing data to pc "!!
SOURCE:
My panasonic camcorder is sdr-h40 i can't load my videos in to my pc sence i've upgrade my computer from windows xp to windows 7 my sd card/hard disk video camera software video cam suite 1.0 is not...
Hi, the VideoCam software isn't compatible with Windows 7, but you can still copy videos and pictures to your computer and edit or view them with other software. Videos are saved by default as MPEG-2 files, and photos are saved as JPEG files -- both of these formats are recognized by a wide variety of programs. (For example, Microsoft's Picture Viewer, which comes with Windows, can display JPEGs, and Microsoft Office Picture Manager can edit them.)
Dec 20, 2010 | Panasonic SDR-H40 HDD Camcorder
I bought a Panasonic SDR-H80 HDD that did not come with the software. I am unable to transfer video onto my pc. I need the software/driver. Where can I find this to download?
Panasonic's support site does not offer software for this camera, only manuals. If you don't have a manual, it is worth getting one to find out what specifically you need to do to transfer to computer. Put your model number into the search box on THIS PAGE.
Nov 19, 2010 | Panasonic SDR-H40 HDD Camcorder
I have a panasonic camcorder sdr h80 hdd with
It may or may not work, but try installing as Administrator and setting the program's EXE into "Compatability Mode for XP SP2",and also, running as Administrator. Windows 7 just doesn't want to support any hardware over like a year old... Drivers are a HUGE issue. Especially for older stuff. Compatability Mode is one way round it but not always. Also you will have to set to OFF digital Driver signing at bootup press F8, and at the bottom you will see driver signing.... EVERY TIME you boot you MUST set this OFF, or it will simply not work, thats if it does install anyway. You MUST have it OFF to install as well.
Apr 16, 2010 | Televison & Video
Dvd software wont download for my sdr-h80 in
Dear i hope this answer will right for the solve your problem.
And for solution of your problem.
i have send this link for your problem.
This software is for Windows 2000/XP/Vista only! You can download Windows 9x version from here.
Feb 14, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
Can't transfer videos to dvd with my Panasonic SDR H40P
Apparently the software that Panasonic sent with my video camera is not compatible with Windows XP Service Pack 3. The solution is spending $79 on another software. Not happy about it, but grateful for your exper that helped me get this resolved. Thanks.
Jan 03, 2010 | Panasonic SDR-H40 HDD Camcorder
Panasonic SDR-H80, Need service pack for video cam
I hope you have WIN XP on your computer. Windows XP has 3 versions of service pack (SP) available. SP1, SP2 and SP3. For more information on obtaining SP, please refer:
http://support.microsoft.com/kb/322389
Following is the direct link for downloading SP3
http://www.microsoft.com/downloads/details.aspx?FamilyId=68C48DAD-BC34-40BE-8D85-6BB4F56F5110&displaylang=en
NB: SP is a huge file and will take long time depending on the speed of your internet connection. SP2 download would fail in 'dial up' internet connection. Also installation of SP will take a long time, depending on the configuration and the performance of your system
Dec 16, 2009 | Panasonic SDR-H40 HDD Camcorder
Failure to download clips to the PC from my camcorder SDR-H80
HI Yahiya. Most likely you previously installed videocam suite software using the NTSC format. Try reinstalling it using PAL format. This is the same problem i encountered on a Panasonic SDR-H90. I hope this will solve your problem.
Jul 01, 2009 | Panasonic Electronic Whiteboard Mobile...
Panasonic SDR-H80  Hard Drive Camcorder Logo
1,278 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
