Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pictures not appear
I have a sony TV (Triniton/WEGA).
Some times pictures not appear and the stanby-red light blinking.( It blinks 4times continuously and 15times in a minute.)
Could you please let me know the problem cause?
Chetiya
Anonymous
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Dec 28, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
25920
Points
232
This could be a leaky picture tube. will require a crt rejuvination machine to clean the tube elements
2answers
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
2answers
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
1helpful
Have a sony kd32fs130 and after limited viewing the picture goes out. I still continue to have sound but no picture and the red light blinks. Which part I need to change?
How many times red light blinks when TV lost picture? There would be interval of 3 seconds in red light blinks so count pause to pause and let me know.
1helpful
Stand By timer light continues to blink on Sony Triniton TV
That problem comes up when one or both of the convergence IC's are burnt ... it normally has an "STK" number on it screwed onto some large aluminium heatsink ..... however if you venture to change it get back to me ... I'll try to guide you through ....
1helpful
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
2answers
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
2answers
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
