SOURCE: remove write protection on a walkman nwz-s616f
I had the same problem after using this product for a month, suddenly it showed the warning of write protection.
I even contacted the sony customer center but to no avail. their answer was of no help at all.
so here is what i did to make it work:
1) First install "QuickTime version 7.2" or later (you can download it from torrent if you are unable to register it, i.e. with a crack)
2) Then install "Windows Media Player 11 " (you can download it from torrent if you are unable to validate it, i.e. if WinXP not original)
3) Now install "Media Manager for WALKMAN" (a compatible software provided by the sony company to interact or communicate with the walkman), freely available for you to download at sony's website.
After the installation, connect the walkman to your computer. Now it should easily add or delete data from you walkman using this software or without it as well.
SOURCE: Media Manager for Walkman 1.2 does not recognize Sony NWZ-S615F
look up here: http://www.sony.com.my/support/faq/1169186/product/nwz-e435f/print
SOURCE: My Laptop wont recognize my mp3 player Sony walkman NWZ-E438FBLK
Was having the same problem. All I did was plug it into my usb port in my laptop, made sure HOLD wasn't on, and then hit the reset button. A few seconds later my computer recognized it. All the songs and everything I had on there previously are still all there. Hope this helps. :)
SOURCE: NWZ-W202 is not recognized by computer with window
i had the same problem, after trying everything i and helping friends could think of, i just wiped my entire pc reformat n started from scratch, once i did that, before installing anything at all, i plugged her in and she workd straight away and has continued to work. HAPPY DAYS
I would try another computer if that did not work the unit is what we called bricked, now you could go to sony.com and see if they can help you to try to get thing back in order please do try my solution first if it does not work the unit is defective.
Thanks and please do use the thumbs to rate this solution and advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
