Question about Archos 504 500870 Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
My unit runs fine as long as it is running with it's power cord plugged in. As soon as you unplug the cord or try to power the unit portable, the following comes up after the Archos wording appears on the screen: "! Shutting Down" and then it immediatly shuts itself off!
I have charged it many hours and then checked the battery and it shows a charged reading, so I don't believe this is a battery issue.
Any suggestions? Thank you.
  • betterbuys Feb 24, 2008
    New battery arrived and I charged it for at least 5 hours. Still having the same exact problem even with the new battery! Any other suggestions before I throw it all in the river?
    New Friend:
I have a Archos 404 30GB. When i connect the usb cable it become Shutting Down. What is the problem. I used many cables but it gives a same problem. Please help me to solve this problem. Thank you
Posted on Apr 06, 2013
  • preciousp58
    preciousp58 Apr 06, 2013
    Genius:
  • 1,067 Answers
Bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Posted on Jan 28, 2008
SOURCE:
Can your washer front load run off a portable generator power
You probably fried the control board. The older machines would work fine on a generator but the newer ones are sensitive to power fluctuations.
Nov 01, 2012 | Bosch Nexxt 300 Series WFMC2201UC
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Output is only 99 to 100 volt. Unit works fine
hmm.... try running it for a while with something plugged in that won't mind the voltage drop... like a light bulb..
Dec 05, 2009 | Honda 3000 Watt Portable Generator
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
The generator runs fine but will not give us any powere
Hello, Has this generator been setting for awhile or was it in use when the power ever came back on? Have you tried to repolarize it? To do this , Shut off the generator and unplug any cords or wiring from unit. Take a electrical cord that has a plug on one end and seperate the wires on the other end of cord. Strip the ends of the wire back about half an inch on each seperated wire.Plug the Male end of the wire into one of the 110V recepticles. Connect one of the ends of the wire you stripped back to the positive side of a 12 volt battery. Now with the other end of the wire you stripped back touch it to the Negative side of the battery for 1 sec and remove it. Unplug the wire from the recepticle and battery. Fire up the Generator and check the voltage! This repolarizes the unit and fixes most non generating problems from Non use and back feeding! Hope that helped! Rick
Jun 28, 2009 | Coleman Electrical Supplies
UNIT SHUTS DOWN AS SOON AS COMPRESSOR KICKS IN
Hi fdisc I feel quite sure your compressor is going straight to ground you need to get someone to check the comp, for its resistance and he or she will soon let you know for sure.
Regards
Steve.
May 24, 2009 | Danby DPAC8020 Air Conditioner
Cursor stops working when power cord is plugged in...
It sounds as if the power coming through your ac adapter may be causing interference with the touchpad, meaning perhaps an electrical signal is crossing into your mouse or disrupting its signals.
You could try to download the latest drivers for your touchpad and see if that fixes the issue.
You should also (if you haven't already) try a different mouse to see if the issue is related to the mouse sub system, or the touchpad itself.
If possible, try a different AC Adapter to see if that may be the issue.
Mar 27, 2008 | Dell Inspiron™ E1505 PC Notebook
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Archos 504 500870 Digital Media Player Logo
225 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
