Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
That would be a H50 engine. Here is a link to the service manual. Look in governor section and find your particular setup; there are several to chose from.
Usually a Tecumseh with these symptoms has a clogged jet somewhere. If you dismantle the carburetor and clean out all of these tiny holes with a wire or something and spray it off with carburetor cleaner and reassemble it, it should work. Turn the adjustment screws in just until they touch the seats counting the turns and reassemble it with them the same number of turns off of the seats. Also, put fresh gas in it if you haven't. Gas being left in them is the main cause of this. If you put Sta-Bil in the gas before putting it away or run it out of gas it should prevent this from happening in the future.
