I have problem on my hp laserjet 3005 don't print OK i change the tone and the laser scan unit and still the problme on the printer give blank page (there is no details shown on the paper) i need to fix it please help
Symptom: Black or Blank image while copying or scanning. Part suspect rating: Scan head..70% Scan head cable...25% Formatter...5% For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check... Replace scan head
hi
the cover that pritect the laser unit is closed; the release lever of LSU is not actuated; try to open the front cover and look inside is the lever ok , if broken block it with plastic parts to get the LSU on. if LASER beam does not reach te drum unit you have a blank page because the drum was not scanned.
Check one of the followings: Paper jammed anywhere visible? Rollers, etc? All the trays are closed properly? Toner, Drum Unit or the Fuser Unit don't need changing?
See if you can print out the Printer Status of the Printer from it's menu which would give you some statistics of what needs to be replaced etc.
Contact your HP Dealer nearest you to fix that problem, it could still be under warranty so there'll be no added cost to you.
If ink is ok , then you may need to reinstall printer drivers.
Unplug printer USB. Go to control panel>>Installed printers and delete existing printer installation. Reinstall printer driver software using printer CD.
