Hi, i have the saem problem as some other people ahve had with connecting the rear speakers.
I have followed all steps inluding dell trouble shooting guide with no luck.
I have manged to get rear speaker to sync when pressing connect on speaker and test tone button on bass box and have heard the test tone through it and also get a power on off sound when switching middle speaker on, further more i have adjusted sound settings on pc to 5.1 and used a test tone through the pc and heard that but when i play a cd on media player or radio i have no sound.....i have a dell XPS720 with xtreme sound card....can you help ?
Many thanks in advance.
Hey there Subaquakid, the nature of surround systems is to identify separate extra channels of information and send them to the right address, being the selected speaker. In order for the rear speakers to work they need to be sent a signal. The media which you are using may not have the rear channel encoded. therefore the rear speakers have nothing to announce. Please ensure your source cd has the suround feature encoded. Hope this helps. Good Luck!
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
thanks for your quick response, thing is every media i have tried has no result, radio,cds,itunes and so on ?
