Bad day, huh? Here area couple of quick and easy things to try that may fix your problem. Then again, they may not,but it never hurts to try!
Step1
1) Take out your laptop battery.
2) Remove your AC power cord, that's the wall power, removeit.
3) Now hold down your poser button for at least 30 seconds.
That will drain any static electricity that has builtup on your laptop system board and many times fixes the problem of ablack screen. After the 30 seconds re-connect your laptop to the wall power andhit the power button normally and see if the laptop comes back up. Reinsertyour battery.
If that doesn't resolve the situation try step 2
Step 2 Bad memory Your memory (RAM) may need to be removed, andthen put back in (reseated).
The videoshares the system's memory, and will not function if there is a problem.
1) Reseatmodule(s).
2) Swapmodule, preferably with known good.
Hope this helps the situation and makes your day go better!
Ron
