Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
Posted on Apr 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on steady for a couple seconds then back to flashing. Kept repeating this sequence. Took a while for this sequence to start. Green light never came on. Tried putting the battery in 3 different times all at room temperature. A p104 and a nicad battery both charged fine. Am I correct in assuming the p103 battery is bad? The charger and p103 and 104 batteries are all reconditioned and right out of the box.Thanks for the help. Greg
Dan Apthorp
Level 3:
  • Ryobi Master 2,824 Answers
  • Posted on Apr 10, 2017
Dan Apthorp
Ryobi Master
Level 3:
Answers
2824
Questions
0
Helped
889986
Points
7391
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
2 Related Answers
Anonymous
  • 83 Answers
  • Posted on Aug 13, 2009
SOURCE: Can I leave my Ryobi P113 charger with a P103
Yes you can that is an automatic charger when it is fully charged it shuts down the charging portion but keeps the charged light lit however this does not effect the battery.
Editor925
Dean
  • 285 Answers
  • Posted on Feb 24, 2011
SOURCE: What Ryobi batteries p103 or
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Red "testing" light comes on when a battery is inserted and flashes continuously. Green light does not come on.
Actually, this is normal. You have to wait for the test to complete, and then it will charge your battery.
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
What is the difference between Ryobi P113 and P114 power tool battery chargers?
The P114 comes with the P116 package (Lithium Ion starter kit) and according to the Home Depot blurb about it "The charger is Energy Star rated and optimizes battery life cycles". The P113 charger is not Energy Star rated and the manual recommends removing the battery after charging and possibly the P114 does not require this.
Jun 21, 2011 • Garden
1helpful
Is there a difference between the ryobi p103 lithium battery and the ryobi p106 lithium battery?
p103 is name of the battery. p106 is the kit with 2 p103 batteries. same thing just 2 times. the p104 however is bigger and holds more juice.
2helpful
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
5helpful
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
3helpful
Can I leave my Ryobi P113 charger with a P103 battery inserted in it for an indefinite amount of time with the charger plugged in, without doing damage to the battery or charger? Thank you. Phil
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
