Polaroid TLA-01911C TV Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PROB LEM WITH POLAROID TLA-01911C
THIS TV POLAROID TLA-01911C, WHEN TURN IT ON IT JUST COMES UP WITH JUST A WHITE SCREEN. WHEN YOU TURN IT OFF YOU MUST UNPLUG IT FROM THE POWER.
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Jul 16, 2012
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011580
Points
4641
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Sep 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
27210
Points
20
It is related with Power
  • Anonymous Sep 21, 2010
    It is related to Power & Inverter Board. Price is around 80 dlls.
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
When I turn on my tv the screen is white and nothing else happens.
This is a common symptom of a power supply failure on the TLA-01911c. The board has parts called capacitors that filter the output power and when they go bad the power supply does not power up right. The unit can either have no power, just a flashing power light, just a white screen or it could take a long time to show a picture. Here is a link to a repair guide that shows what to replace on the power supply board to repair the unit.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps you get your TV bad up and running,
BuddyMc
1helpful
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
My TV has a white/gray screen when I turn it on. I get nothing else, no sound either.
A white or gray screen usually means the power supply board is not functioning correctly. Below is a repair guide showing what to look for on your power supply board. Open the back of your TV and look at the power supply board as shown in the repair guide. If the capacitors are bulging on the top then they have failed and replacing them should get the board and TV back up and running. This is a very easy repair if you can do a little soldering.
I hope this helps,
BuddyMc
1helpful
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
2helpful
Hi the tv just went to a white screen..nothing..what could be the issue..
Ur tv still have sound when the screen are white?Yes?The Tuner board is dead,need it replaced.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
1helpful
2answers
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
