Mitsubishi WS-55809 55" Rear Projection Television Logo
Posted on Jan 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Mitsubishi hd1080 medallion model # ws-55819.
  • Nygle May 10, 2008
    picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for awhile (heat's up?). Can i fix this myself? How is this repaired?
  • Anonymous Mar 06, 2009
    same problem
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Feb 03, 2008
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1723440
Points
23750
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
I need a power supply for a Mitsubishi Medallion WS-55819
did you try contacting the Mitsubishi service center for the part?
I have a Mitsubishi WS-55819 and the screen is curved and looks 3d. The colors are also blurry. When it warms up it looks better. Any suggestions?
It could just be the solder on the convergence ICs which needs to be reflowed. If that doesnt help then the ICs will need replacement. Your model uses 2 of the STK392-570 ICs. If you need further assistance please let me know.
Thanks
Sonny
8helpful
2answers
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
3answers
1helpful
2answers
Colors are bleeding and picture blurred. Can't adjust convergence settings.
Replace the two Convergence amp ICs they are both STK392-570 Ics you can get replacements at the following link with free instructions on how to remove the old and replace the new ones.
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
1helpful
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
23helpful
3answers
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
