Question about Samsung 953BW LCD Monitor
Samsung 953BW monitor. Blue light is flashing but no picture.
Samsung 953BW monitor. Blue light is flashing but nothing else works. Computer is on and has been restarted multiple times but still no monitor. Only flashing blue light. Any suggestions?
    New Friend:
Hi, i have the same problem...any solution?
Posted on Jun 26, 2010
SOURCE:
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
My Samsung SyncMaster 205 bw monitor was working a few days ago. And the suddenly some black and white slanted stripes appeared on my monitor. I shut off my PC and rebooted it and nothing came up. My blue...
Sounds like your monitor has croaked. Borrow a monitor from a neighbor, friend or family member just to see if it works. If it works, your monitor is bad. If the borrowed monitor has the same issues then your Video Card in the computer is bad and needs to be replaced.
May 01, 2012 | Samsung Computers & Internet
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
I have a Samsung monitor, model #953BW. I put the computer to sleep last night and this morning the monitor will not display anything. It is the monitor, not the computer, as another monitor works on that...
At this point you need to open up the monitor and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 06, 2010 | Samsung 226BW Monitor
Samsung syncmaster 953bw
Oct 23, 2009- This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. Oct 23, 2009- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Sep 26, 2009 | Computers & Internet
Unable to get Samsung monitor 953bw to 1440x900 resolution. The option doesn't get displayed in graphic properties window.
Dear,
Sea u r Display properties, wether u have installed a right VGA driver. If u have installed right one please install new version of the sa,e.
Cheers
Jaggu
Sep 21, 2009 | Samsung SyncMaster 953BW 19 inch Monitor
Samsung 953BW blue power lights just flashes when turned on nothing visible on screen with no computer connected
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 31, 2009 | Samsung 953BW LCD Monitor
Open Questions:
SBCglobal CuStOMeR Care PHoNe@[+1-855*536.5666] NUMBER HELPLINE Southwestern Bell Corp stands for SBC; previously it was a holding company. Afterward, after broke up from AT&T, it expanded to the SBCGlobal. SBCGlobal is one of the excellent service providers of various online services, and its services are used by millions of users worldwide. Presently, SBCGlobal is famous for providing outstanding email services with rich feature and functions, but many times, these extraordinary features create lots of issues in accessing the email account, for these issues, the SBCGlobal email customer support is available for troubleshooting these common issues. The experts have wide knowledge and experience regarding SBCGlobal email. Get-in-touch with the SBCGlobal email support phone number and expert will assist you with instant solutions. Whether you are unable to log in or log out of your SBCGlobal email account, resetting password issue, recovering the hacked account, unable to create a new email account, get connected with the customer service professionals and know how to troubleshoot these issues. The skilled professionals help you in every SBCGlobal email related issues; you just need to dial the toll-free number of SBCGlobal email customer support. Avail instant resolutions and troubleshoot your bugs and glitches that triggering in accessing the SBCGlobal email services. Moreover, get connected with the technical team via phone calls, online or live chat and assist you remotely when needed.communicating and transferring data, information, media files and whatever we want to share with someone else in just one click. Therefore, users always need secure and rich feature email services, to fulfill all their requirements users usually choose SBCGlobal. However, this division of AT&T is very well known for providing excellent customer support with 24/7 customer service. The experts available at SBCGlobal email customer support have a wide knowledge regarding SBCGlobal email. Get-in-touch with the certified professionals by dialing the toll-free number of SBCGlobal email customer support.
Sep 20, 2019 | AT&T Computers & Internet
MAGICJACK SUPPORT NUMBER 1.845481.1722 Online Magicjack Support phone number [1845481-1722] Magicjack is a great platform forunlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Magicjack prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Magicjack will be resolved instantly at a single call to customer support.Experiencing issues are somewhat inevitable occurrence, but why get hampered while the expert professionals at customer care Service are dedicated to help you right at the time when you call them. Yup! This is much easier and hassle-free. Your one call can resolve you every issue. So, no more waiting, contact experts now!Magicjack is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Magicjack Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Magicjack will be resolved instantly at a single call to Magicjack Support Number USA +1-845-481*1722
Sep 20, 2019 | Expert Computers & Internet
SBCglobal TecH SuPPoRt PHoNe@[+1-855*536.5666] NUMBER TECH SUPPORT Southwestern Bell Corp stands for SBC; previously it was a holding company. Afterward, after broke up from AT&T, it expanded to the SBCGlobal. SBCGlobal is one of the excellent service providers of various online services, and its services are used by millions of users worldwide. Presently, SBCGlobal is famous for providing outstanding email services with rich feature and functions, but many times, these extraordinary features create lots of issues in accessing the email account, for these issues, the SBCGlobal email customer support is available for troubleshooting these common issues. The experts have wide knowledge and experience regarding SBCGlobal email. Get-in-touch with the SBCGlobal email support phone number and expert will assist you with instant solutions. Whether you are unable to log in or log out of your SBCGlobal email account, resetting password issue, recovering the hacked account, unable to create a new email account, get connected with the customer service professionals and know how to troubleshoot these issues. The skilled professionals help you in every SBCGlobal email related issues; you just need to dial the toll-free number of SBCGlobal email customer support. Avail instant resolutions and troubleshoot your bugs and glitches that triggering in accessing the SBCGlobal email services. Moreover, get connected with the technical team via phone calls, online or live chat and assist you remotely when needed.
Sep 20, 2019 | VIA Computers & Internet
SBCglobal CuStOMeR Care @[+1-855*536.5666] NUMBER CUSTOMER SUPPORT SBCGlobal is the part of Southwestern Bell Telephone Company which is owned by AT&T. AT&T is one of the leading telephone and internet service provider company of the United States of America. Well, SBCGlobal is one of the popular email service providers which is offered by Yahoo. Nowadays, we all know that email is one of easiest Southwestern Bell Corp stands for SBC; previously it was a holding company. Afterward, after broke up from AT&T, it expanded to the SBCGlobal. SBCGlobal is one of the excellent service providers of various online services, and its services are used by millions of users worldwide. Presently, SBCGlobal is famous for providing outstanding email services with rich feature and functions, but many times, these extraordinary features create lots of issues in accessing the email account, for these issues, the SBCGlobal email customer support is available for troubleshooting these common issues. The experts have wide knowledge and experience regarding SBCGlobal email. Get-in-touch with the SBCGlobal email support phone number and expert will assist you with instant solutions. Whether you are unable to log in or log out of your SBCGlobal email account, resetting password issue, recovering the hacked account, unable to create a new email account, get connected with the customer service professionals and know how to troubleshoot these issues. The skilled professionals help you in every SBCGlobal email related issues; you just need to dial the toll-free number of SBCGlobal email customer support. Avail instant resolutions and troubleshoot your bugs and glitches that triggering in accessing the SBCGlobal email services. Moreover, get connected with the technical team via phone calls, online or live chat and assist you remotely when needed.
See all Samsung 953BW LCD Monitor Questions
Samsung 953BW  LCD Monitor Logo
3,321 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
