I have a 2 GB Sansa c200 and I have the software installed to load songs but when I try to drag songs over it says they cannot be imported. If I try to go to convert media files, I find the song folders but no songs inside. I have looked under all file types but no luck? Help please!
I have a c200 player,,the other day it just wiped my music out,,now if i try to load new its showes copyed,,but there is nothin there,,any ideas,,,thanks chuck
I have sucessfully loaded my player with all sound formats. Then...my music got wiped out. Now..I can't load any mp3 formats back onto my player. I have the player set to MSC and I am using Media Player to download. My computer loads some music but shows "ready to copy" on the mp3 format and won't copy to the player. Totally bummed. Any ideas?
You dont have to do all dat stuuff above, i went through the same issue and all you have to do is download a mp3 file from limewire for example or whereever and then drag and drop it into windows media player, also you can rip songs from cds and then you drag and drop the songs in media player to the column on the right of the media player. when there in the column you press sync and they appear on the ipod.
The best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
SOURCE: Can't load songs
ive had this same problemo. you cant use the media converter to drag and drop songs. you have to download your songs or rip them onto windows media player. you plug in the sansa and then when its recognized there will be an area on the right hand side where you drag the songs and they appear on sansa.
It's a c250. I feel very dumb right now
I have the same problem, I did read the manual 15 times and I still can't seem to get it!!!
