I have a Dometic rm2652 refrigerator the bottom door hinge broke at top . Do i have to replace the door or can I replace the plastic hinge on the door
The hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
It is the plastic broke off with the hole in it , it is the plastic that runs across the top of the door.
I have the same problem.. Yes its the part with the hole in it.
Is there a guide to replacing the electrode on a dometic rm2652 refrigerator?
