We have a Luxembourg-purchased JVC TV 20 inch that we purchased last year. We are trying to hook up xbox 360 and do not have the instruction manual (or can't find it) for the TV. We plugged in the yellow, white and red cables into the back of the TV on the side, plugged in the TV and plugged in Xbox and hooked up the internet. We are getting sound only but can't get the picture. Any suggestions?
Change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
I've had the same problem. If you got your Xbox 360 with an HDTV cable with red, yellow and white inputs as well, don't plug those in. Where yellow should be plug in the green cable for HD hookup. Plug the white and red cables where they should be. This should give you a black and white picture. I know it's a little disapointing, but that's as far as I got.
Check your tv video inputes make sure your tv is on the right input this should solve your problem. you may have to use your remote to change your tv inputes.
We're having the exact same problem!! We tried every input on the system (Video 1, Video 2, DVD/LD, Through the VCR, directly into the TV). We can hear the sound but get no picture. This is an older TV, but it has the standard coaxial imputs (red, white yellow). What's Wrong!!!???
ok jvc yelow red and white in front help me if read please email me at [email protected] or [email protected] ok can't get picture at all please elp 360 pluged bin help
I have the same problem. Any help?
i have the same problem
i put the green hd plug in the yellow also, and got black and white picture, but it flickers so much i cant see
how do i fix it?!?!
i think its set to HD, because i bought it from someone else, how do i set it back!?!?! email me at; [email protected]
please!!!!!
thanks
