My philips senseo machine is only producing very waterery coffee with new pods inserted. Can this be fixed? Thanks
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
The Senseo is designed to issue 1 or 2 cups of coffee depending on the button pressed. The pods themselves are designed for one continental size cup of coffee not mug size. Can you confirm you are using the pods on single cup only not trying to get two cups from one pod to fill a mug?
