Flickering can be adjusted. To get more details; just Google for the site "Electro help". There is more details about how to rectify this fault. Surf the site with patience.
Do you smell anything electrical such as a burning smell?
Sometimes the ice maker can screw up and make some sounds.
When you have the door open does the light stay constant or flicker? If it flickers then you defiantly have an electrical issue. and should be serviced by a licensed repair person.
Hi trust me change your battery for a new one and have the rectifier tested that's the little aluminum block that looks like a amp for a car speaker I bet that's your problem and if it has lights try turning em on n if they flicker on tickover it points to poor vaultage in battery or rectifier isn't holding enough volts but cheapest first get battery tested maybe knackered if still have problem deforestation rectifier hope it helps
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Probably the alternator again. If you have a voltmeter or there is one in the car, check battery voltage with car running. It should be at least 14 volts. Not 14 volts or no voltmeter--take alternator off and have tested at parts chain. Let me know if you need instructions or have more questions, and thanks for using FixYa.
these are capacitors that are burning. also, the resistors are really going threw major stress. i would remove the CRT monitor from the plug and, rebuild the power board immediately before a fire starts. This is a power board issue at the moment but, it will spread as long as power is still running threw the monitor.
