Expert
- Posted on Dec 27, 2009
Re: How do i jook up my playstion 3 to the internet via...
1st Step: Setting up the Internet Connection
When making a wired connection to the Internet, you do not need to
adjust any of the default settings. If you cannot use the default
settings to connect, follow the instructions below to adjust the
settings.
- Select "Network Settings" under "Settings" in the home menu, and then press the X button.
- Select "Internet Connection Settings", and then press the X button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the X button.
- Select "Wired Connection", and then press the X button.
- Select "Easy" or "Custom" and adjust settings as necessary. (Easy is recommended)
- Follow the on-screen instructions to adjust the required setting.
Easy: Basic settings are set automatically.
Custom: You can manually enter detailed settings information.
Here's a diagram set up to PS3 wired internet connection
You can take a look at the connection diagram here
