Http://www.unlocking4u.com/nokia-5310/rs6wp9/ will give you the unlock instructions for your nokia mobile.
Nokia 5310 Unlocking Instructions
Warning : Do not enter any wrong unlock
codes on your Nokia 5310 mobile phones. If you enter over a certain
amount of wrong unlock codes on your Nokia 5310 mobile phone, your
phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5310 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5310.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5310 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5310 mobile phones locked to the network Fido in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5310
Each Nokia 5310 mobile phone has an unique unlock
code. You can buy the unique unlock code for your Nokia 5310 mobile
phone using the form above.
SOURCE: nokia 5310 security code unlock
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
SOURCE: unlock nokia 5310
hi there,
here i post some instruction you can follow to unlocked your mobile it is easy hope it will help you to solved your problem..
any further assistance you want you can log on this site...
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
SOURCE: unlock memory card for nokia 5310
u must have set a password earlier..... try to remember it or else u can hard format it.....
