A 3 then 4 flash sequence is showing the Freewheel Lever is in the freewheel position and the scooter cannot power the wheels. Turn off the scooter move the lever firmly in both direction 2 or 3 times then leave in the 'Drive' position. Turn the key back to the On position and check to see if the flashes have stopped.
As Scooters age these switches can wear out and fail and all you can do is replace the switch assembly as they are often a 'Non Repairable' part.
Yes I done a quick search on the beeps it took me to the same fault codes as the book TRY SENDING AN EMAIL TO www.pridemobility.com.au....good luck..Hi again yes I just picked up the fault book and they call them flash codes I WILL CHECK INTO THE PROBLEM cheers. Hi 3 flash code unplug charger turn key of then back on again , 1 flash code charge batteries 2 code same as 1 charge batteries good luck
a steady blue light means all systems are a go. if it flashes that is a flash code saying something is wrong. Refer to the manual for code meaning Scooter Doctor App
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Error code 8 means an internal controller error or problem and requires replacement of the controller. If Medicare purchased your scooter then contact a provider to get repaired or you can call a service company such as Roadrunner Mobility at 1-800-467-2668 or Repair Xpress at 1-877-581-3733 and they will bill Medicare for most of the repair costs. Hope this helps
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
