iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn on¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.
Do you have the usb cable that came with the camera? If so plug that into your computer and your computer should them recognize it and give you instructions. After your files are saved to your computer add them as an attachment to your email and send.
It's Nikon's file system.
You must use cord/charger/station to access memory card.
Without it, your computer doesn't recognize it and ask you to format the card.
