Coby MP-610  MP3 Player Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Format error Coby mp3 mp610
Keeps saying "format error" tried to reset it with small "button" in back and it's not working? Any thoughts?
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882692
Points
4663
Coby has released a firmware upgrade for the MP-610 MP3 Player. I recommend you download it and run it to fix your device. You can find the download and installation instructions on the Tip I posted on the FixYa Website.
I hope that helps.
nwhite103
Level 1:
  • Contributor 3 Answers
nwhite103
Contributor
Level 1:
Answers
Questions
0
Helped
2578
Points
9
MP610 firmware only fixes the 'File System Error', if your unit is saying format error, then your songs are not MP3 or unprotected WMA files.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
985
Points
Que hago cuendo da error de systema de archivo
6helpful
How do i play videos on my coby mp610-8g? it just says format error i've synced using windows media player but no luck
There are a few versions of the MP610.
The newer versions come with Coby Media Manager. When you connect the MP3 player to your computer, go to Start > Computer 'My Computer' > Double click the "C" with a big red circle. This will load Coby Media Manager, in Coby Media Manager, click Movie on the left hand side, the software will scan your computer for video files, right click the video file and click sync, this will convert the video to the correct format.
If you have an older version, You can download below software that will allow you to convert to MTV video format:
http://www.cobyusa.com/files/software/VideoConverter_MP610.exe
Once the video is converted, save the newly converted video file to the MOVIE/VIDEO folder on the Removable Disk drive that shows up under Computer 'My Computer'.
2helpful
1helpful
Help with coby mp610/ac wont boot compleatly after format
After the format you might be missing files for operating the device.
Formatting the player is normally used before updating the firmware.
Have you been updating the firmware after you formatted the player ?
There is a new firmware release for the MP610.
Look in the support page, enter MP610 in the bar (Product Search) of next site:
http://www.cobyusa.com/?p=support
Download the zip file. Unzip the downloaded file with WinZip or WinRar.
Look in the pdf file for the instruction how to use the exe file for the
Firmware Update.
I put some files on my mp3 player. when i go to play them it says format error. however, that isn't my major problem. now my computer keeps telling me to format my mp3, which will wipe my entire memory,...
Files on the MP610 could be in the wrong format or corrupt. For the correct format look in the manual on page 40:
  • cobyusa.com/files/manuals/MP610_MN.pdf
And there's a firmware update for this issue for the MP610, see next site:
  • cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
For the update look under Downloads and select the zip file MP610_firmware_update.zip:
1. Right click "...update.zip"
2. Save Target As... to save the file to a location on your computer
3. Unzip the zip file: an instruction for how to update the LCD firmware
is included in a pdf file.
Hope this solves your problem. Just post a comment in this thread, when needing more help.
12helpful
3answers
My coby mp610 video player needs a mtv format converter. I cant find one online. I need it free as well. Any links?
Support for Coby media players is on cobyusa.com .
For the mtv converter, Coby Media Manager must be installed .
  1. Enter cobyusa.com as the address in Internet Explorer
  2. Next select the Support link
  3. Choose the fix for MP822 and follow the steps for the download of your operating system.
  4. After the download, install the file for Coby Media Manager
  5. Run Coby Media Manager: on page top in Tools > Device manager... select the MP610 in this converter.
  6. Add the MP610 and click OK to setup this device
  7. For the setup of the audio format added to the mtv video format, select DEVICE on the left side and next on the right side under MP610 select Device Configuration
  8. For the MP610, under the tab [Output file format] the audio bitrate can be changed, the audio format is fixed MP3; the video format is fixed MTV; the image format is fixed JPG .
On page top under Help find more information about using the software.
I'd appreciate your vote when this information was helpful.
When needing more help, just post a comment.
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
1helpful
I am trying to download from my computer onto my new mp610-g and when trying to play the downloaded files, get the format error. what do i need to do?
The support site for the MP610 can be reached here:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
Under Downloads there's:
A firmware update for File Sys Error and a video converter for converting videos before transferring them to the player.
To get the matching formats for the player:
1. Get the video converter for the MP610:
For getting this execute file right click it and select "Save Target As..." for saving it to location on the computer. Use the converter
for all videos before transferring them to the player.
2. Use the Coby Media Manager for transfers of all media.
A download for this Media Manager can be found here:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
For getting this execute file right click it and select "Save Target As..." for saving it to location on the computer. After that run the execute file to install Coby Media Manager.
For a setup of your player in the manager:
Select in Tools > Device Manager... in the devices list the MP610.
Add the MP610 to the favorite devices.
To setup the output file format for the MP610 select under the DEVICE menu in Coby Media Manager the Device configuration.
Setup format for video is MTV (cannot be changed for the MP610)
Setup format for audio is selectable 96 kbps; 128 kbps; 192 kbps.
When this information helped, I'd appreciate your vote.
If you need more assistance, just add a comment.
1helpful
COBY MP610-2G - FILE SYSTEM ERROR
you may have to get a firmware update
(download to computer, install utility, wire up player, run update..)
you will find firmware, specs sheet and manual for download here:
http://www.cobyusa.com/?p=doc
after doing the update, access player via win-explorer, erase all the mp3s(do not format!, as this will erase the firmware as well)
and drag and drop your new mp3/files onto the player.
unplug, press play and if everything is right: enjoy listening
Kids formatted mtp player coby mp610-2g
the player still has software built in. movie files need to be in mtv format with 160x128 or 128x90 resolution for player to work
3helpful
2answers
Coby mp610 2g mtv unknown format
Hey try to get the video file you are converting to .mtv to convert to .mov first.I had the same problems until I tried it that way.Someone else somewhere says mpg is a good format that the converter will read well and convert properly.I never tried it though.However I find that .avi files will give you problems.This is because .avi is a container not a format.
Also remember Youtube videos download as flv files and if you use MediaCoder like I do,to convert from flv to .avi you will have problems because the actual format will be Xvid and the container .avi.
fFor the sys err problem..visit the Coby USA website ...there is a firmware fix there.The actual link is on this site in another Coby mp 610 question.
I hope this works...let us know
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
