I'm trying to identify why my 2 year old Sony SXRD KDS-55A2020 now has green faces. The issue started several weeks ago after BrightHouse upgraded their cable boxes. The cable company refuses to give me a clear explanation why this happened to my TV. Not happy with their explanation. Does anyone know what the issue is? Or how do I fix the problem?
SOURCE: SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
SOURCE: Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600
XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working. The tv automatically shuts off in protective mode. Make sure the POWER/STANDBY light is blinking and not the lamp light below it. Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced. If its the lamp light blinking then you need to replace the lamp. The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual. I hope this helps you.
