If the washer spin's than you have a blockage,most likly it is in your water pump.take the discharge hose and lower it in a bucket,if no water come's out than most likly it is in the water pump.you will nead to remove as much water as you can by hand.also you will nead a pot or bowl to catch the water when you remove the water pump from the discharge hose and the large hose that go's from the outer tub and the water pump.with the pump off you should be able to look inside the pump and see the blockage and remove it.
