All of a sudden, the digital oven controls wouldn't work any longer. I can't activate the bake, broil, timer settings, or even change the clock. There's still power to the controls because the clock is still correctly working. The only response I get is when I hit the "clear/off" button, it beaps. All other buttons are inactive. I tried unplugging the unit hoping it would somehow reset itself, but no help. Is there maybe a fuse or something seperate from the clock that works these controls? And if it's something like the heating element, then why wont' the oven timer even activate?
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
I am having the exact same problem!!!
My range that is having the same problem is a Jenn-Air (made by Maytag) Model #JGS8850ADW. We have tried everything the other person has, including taking the control lock off, but none of the buttons even seem to be working...only the cancel button makes a noise when you touch it???
my clock wont set on my oven which is somehow stopping my oven from working
