Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots....visit my support page.
all the best...
SOURCE: No Audio output device is installed
Updating driver will usually work, try doing it manually if it does work auto.
But if not its usually more serious, it may be damage etc.
Regards,
Asitomani
SOURCE: no audio output device installed
first i would see if all my audio drivers are up to date.
use this program:
http://www.drivermax.com/
thanks
CBZ
SOURCE: no audio output device installed is showing and no sound is coming.
if you have xp or vista go to device manager area and uninstall the device then click find new device it should sort the drivers out for you to work again
if it dosent work for you get back to me and ill see what can be done for you
SOURCE: reinstall audio output device on laptop
you might have deleted the driver for your internal sound card go to the laptops manufacturers website and see if you can download the driver again, then reinstall it.
