Question about Brother CS6000i Computerized Sewing Machine
My Xmas gift sewing machine worked perfect stitching for about 18" than all of a sudden an F8 message occured and the machine kept making a clicking noise.
  • 59 Answers
You should put an oil to the needle bar of your machine and to your bobbin. always put an oil if they clicking noise again.
Posted on Mar 27, 2010
SOURCE:
Which sewing machine needle has the bigger eye - 16 or 18
for needle information on eye size , length, and material use search --sewing machine needles size and applications
Aug 02, 2018 | Sewing Machines
Tl2000 and it is skipping stitches while quilting. I have changed the needle. I used needles 14 16 & 18 I have cleaned the machine. When I sew seams I have no problems.
Have you changed the type of needle--top stitch, embroidery, microtex? Sometimes that will help. Also, my skipped stitches occur in FMQ because the fabric is moving too fast for the machine speed or I have a jerky movement. It helps me to try slowing down the fabric movement or speed up the machine and practice making smooth, consistent movement. I've never done FMQ with a needle larger than an 80/12, so you might try a smaller needle to reduce the fabric grabbing the thread.
Skipping the Skipped Stitches in Your Free Motion Quilting
Skipping Stitches
FMQ Troubleshooting Tips Tricks
Oct 31, 2017 | Sewing Machines
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
When you push foot pedal c3 comes up and beeps 3 times
Don't know what machine you have, but this may help:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwigsLfzlJbKAhVB7WMKHYHZAHwQFggdMAA&url=http%3A%2F%2Fwww.singerco.com%2Fpdf%2FFC_Plug_In_Instructions.pdf&usg=AFQjCNEqPAnJbHodHAqfFC95mKH913qZVA&cad=rja
Singer One Instruction Manual Helpful Messages
Error code & would not sew after 2 uses.
4/19/2012
Customer review by DeZooMT
1.0 stars by DeZooMT
Got this as a Christmas gift. Have used it twice since then for little things. Seemed to be fine. Decorative stitches worked and the straight stitches turned out good too. But didn't last. Just took it out to use on a bigger project and it just stopped sewing. The foot pedal wouldn't work at all. The back stitch button would sew though. If you tapped the pedal aggressively at times it would delay and then jump forward 3 stitches and then display the C3 error code saying the foot pedal was disconnected, which it clearly wasn't. Tried the Singer CS line. Was caller number 20, was on hold for 40 mins when I finally got down to caller number 4. All of a sudden the operator hung up the call and stated "their offices are now closed." I was furious. Needles to say, it went back to WalMart and I won't be buying another one.
Jan 06, 2016 | Sewing Machines
Bobbin unthreads my needle and will not sew
Try changing the needle to a new one, size 12, a dull or bent needle will cause this.
Jan 28, 2015 | Sewing Machines
Sewing machine won't stitch
try changing the needle
rethread the machine top & bobbin
if the suggestions don't work, it's possible that the machine
may have jumped time,, taking it to a sewing machine shop
the technican can tell you for sure
Jul 27, 2012 | Sewing Machines
It starts to sew, gets to clip thread and then this E on the display starts flashing and beeping and won't sew, I have a Scandnavia with programable 512 card for my 4D . Checked another card in machine and...
"E" stands for error. Something could be wrong with the design, or perhaps it is not suitable for the machine (too big, etc) Let me know the design you are trying to stitch, and perhaps I can help you figure out the error.
Feb 18, 2011 | Husqvarna Viking 1
Machine is runing along perfect then it will all of sudden start to skip a series of stitches, and then resumes perfectly. Why?
Try leveling up your frame, using a long carpenter's level. Also, check to be sure the wheels on the sensors all make good connection with each other. If one is not, stitches will be skipped when you quilt in the direction of that set of sensors.
Feb 13, 2011 | Juki TL-98Q
Problem while sewing buttonhole with a thick thread
You will need to use a size 18 needle or even better a size 18 top stitch needle. It has a larger eye.Tighten the tension to about an 8 and try it. You may have to lengthen the stitch length to make it sew satisfactorily.. If it won't work on 8 go to 9 and if it still won't work, wrap the thread around the bobbin winder guide (on the left top of the machine) for more tension. It is very hard to sew heavy duty thread on a household machine.
sewman7
Jul 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
206 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
