Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Contact Fossil customer care and they should be able to supply them. Here is their web address: http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html
Depending on the age of the watch you will see indicators of pin direction on the inside of the band. Little arrows that point the direction the pins should come out. If there are no arrows you can look at the edge of the band. You are looking for a split in the pin that makes it look like a screw. The opposite side will be solid. You want to push on the side that is solid so the side that looked split comes out. This is a cotter pin and the split side is bigger and needs to come out first. Use a small punch to push the pins out. Make sure you take links from the band evenly on either side.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out. To shorten the band you have to: Extract the pins. Take link(s) off. Join the rest of band together and drive pins back.
The pins on these watches can be taken out either way, you don't have to worry about if your taking or putting the pins in the wrong way. If you have anymore problems PLEASE let me know. Good Luck!!
You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
I can only give a general guide.
Usually, watch bands can be shortened by removing links. These links are commonly held together by small pins. These need to be removed with a very fine punch. Looking at the ends of the pins, one end commonly appears "split", the other end may look quite smooth. The pin needs to be driven out from the "split" end. 2 will need to be removed to remove 1 link, then 1 replaced to rejoin.
Links should be removed equally, so gar as possible, from each side of the band. Your choice which side if 1 only is to be removed.
Sometimes the ending links are different to the others. It is only the ones that are identical that can be removed.
